Replaced PCM, fuel pump relay, fuel pump, fuel pump relay, but fuel pump not running when key on. truck starts for a second then shuts off.
Feb 12, 2017 at 6:13 AM
HMAC300
✓Experienced Mechanic
check for power and ground to pump is relay sending power? is fuse or fusible link good dual or single tank?
Feb 12, 2017 at 7:49 AM
CJ MEDEVAC
I am not seeing an external pump for this truck, is this a modification?
The Medic
Feb 12, 2017 at 8:40 AM
RICHARD SMITH2
MEMBER
Thx 4 reply,now got pump energized but trk starts and runs rough,hiccups and stalls initially. If I use pedal to idle up engine and maintain 4 several mins she will
Run on her own but still hear hiccups or missing sounds.replaced fuel pressure regulator,o2 sensor also
