brake lights not working, only center lights up
150,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
BOZAE
With the brake pedal applied, only the center exterior break light turns on. Bulbs have been replaced.
Jul 25, 2019 at 12:22 PM
  • 55,583 POSTS
It sounds like the flasher module is out which causes this problem. The hazard switch is the flasher. here are wiring diagrams so you can see how the system works and how to replace the switch:
To be sure here is a guide to show you how to check for power:
Jul 27, 2019 at 7:07 AM
