exterior door handle
248,000 MILES • 5.7L • RWD • AUTOMATIC
JOE1953
  • 809 POSTS
I am trying to replace the right door handle it have two bolts that hold the handle one on inside the door and one on the outside but the bolt that hold the handle on the inside it just have a hole about 1inch for me to use a extension and a 10mm socket how can I replace the bolt with out the bolt falling from the socket when I stick it through the 1inch hole?
Sep 7, 2016 at 12:00 PM
CJ MEDEVAC
  • 11,000 POSTS
Use a piece of cardboard about the thickness of a breakfast cereal box (even thick paper will work)
All you need is a small piece, maybe a 1/4" x 1/4" size, it really don't matter, just big enough to use!
So just tear off a small piece
Sorta straddle the edge of the socket with it
Now CRAM the bolt head into the socket! (squishing the cardboard on the edge)
Half of the cardboard is now between the bolt head and the inside of the socket, the rest of it now dangles out of the socket.
It may be a little tight, but it will go! (I do this all of the time!)
The Medic
Sep 7, 2016 at 12:38 PM
JOE1953
  • 809 POSTS
I have to put the extension through the hole on a angle will I be able to start the bolt on a angle? or would it be better for me to use 1/4" extension other than a 3/8" extension?
Sep 7, 2016 at 1:02 PM
HMAC300
  • 48,601 POSTS
they have magnetic sockets as well for this. or use the 1/4"
Sep 7, 2016 at 10:35 PM
JOE1953
  • 809 POSTS
where do I buy the magnetic socket?
Sep 7, 2016 at 11:50 PM
HMAC300
  • 48,601 POSTS
most tool places or maybe an auto parts craftsman tools may have it which are available all over ace hardware sells them
Sep 8, 2016 at 12:44 AM
