extended starting problem
16,800 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
CLARENCE RAY ELLISON
when engine warm or hot takes longer to start, but runs fine when started.
Apr 20, 2017 at 11:00 PM
HMAC300
  • 48,601 POSTS
if check engine light is not on check fuel pressure with a gauge, if they are low on pressure will cause this. auto parts rent gauge. See link. also, try a wiggle test on crank sensor if it starts quick then the harness there is bad or a crank sensor as they can go bad and not set a code.
Apr 20, 2017 at 11:58 PM
