Explain to the beginner what all of these codes mean
150 MILES • 4.3L • V8 • 2WD • AUTOMATIC
ANONYMOUS
hello people. Explain to me (beginner) what these codes mean 200, g201, p500, c303, c302, c202,220, c201, c203.
Sep 28, 2019 at 6:37 AM
BMDOUBLE
  • 1,139 POSTS
Anything with "G" will indicate a ground. "C" will indicate a connector number and the numbers after the letter will indicate it's position in the vehicle, typically 2 is either the driver or passenger side of the cabin, 3 will be behind the front seats,4 will be in the trunk areas of the vehicle (rear). The P500 indicates a passthrough or "grommet" where the wire harness passes through the body.
Sep 29, 2019 at 4:35 AM
ANONYMOUS
  • 0 POST
thank you!!
Sep 29, 2019 at 4:51 AM
BMDOUBLE
  • 1,139 POSTS
You're welcome!
Sep 30, 2019 at 2:42 AM
