exhaust pressure
120 MILES • 4.6L • V8 • TURBO • 4WD
ROY BURKHAM
two lines on drivers side of vehicle from exhaust to edge of intake where carburetor would be builds up pressure and blows lines off. What would cause that and is that kind of pressure normal? The lines stretched and need replaced or clamped to avoid blowing off.
Aug 16, 2016 at 11:15 AM
CJ MEDEVAC
  • 11,000 POSTS
Can you send us a few pictures? back a little and closer in, especially both ends of the places that blow off.
The Medic
Aug 16, 2016 at 11:28 AM
ROY BURKHAM
It is dark here and I can only text them. I will try to get my daughter to send them tomorrow when it is daylight and she maybe able to send on the computer. Thank you for your help, If you have a text number I will be able to do it.
Aug 16, 2016 at 11:52 AM
SATURNTECH9
  • 30,869 POSTS
Just to add this one you can add images from your phone I do it all time.That way everyone can see what is going on and other users can be helped as well. You could have a bad PVC or made some back pressure in the exhaust.
Aug 16, 2016 at 1:29 PM
