Exhaust Pipe Problem
70,000 MILES • 0.5L • 3 CYL • TURBO • FWD • AUTOMATIC
ANNE BARBER
Exhaust Pipe problem The exhaust pipe under the car has small holes. Mechanic temporarily taped it. It's noisey and outside car gets hot
Aug 31, 2016 at 1:29 AM
HMAC300
  • 48,601 POSTS
if it has small holes it'leaks replace it
Aug 31, 2016 at 2:40 AM
ANNE BARBER
It's not leaking. It's taped however I plan to replace pipe but I'm told to beware that the mechanic doesn't ruin the catalyt converter. I have no way of knowing.
Also do I replace the entire exhaust system.
Aug 31, 2016 at 4:24 AM
HMAC300
  • 48,601 POSTS
normally the time a converter has to be replaced is if the pipe is leaking where the exhaust hooks up. in pic is converter for a 2.3L so if leaks anywhere inbetween arrows in pic that will need to be replaced.
Aug 31, 2016 at 5:06 AM
ANNE BARBER
Thank you. So are you saying in that case both the converter and exhaust system would need to be replaced.
Aug 31, 2016 at 7:45 AM
HMAC300
  • 48,601 POSTS
if the converter has the holes between the arrows or if the flange at rear arrow is cracked then yes. otherwise just the back half.
Aug 31, 2016 at 8:44 AM
