Exhaust leak sound
110,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
DUSTIN BARNETT
This is a new one on me when it comes to cars. So i purchased this car and drove it nearly five hundred miles yesterday drove and ran fine no issues. Today i go to the grocery store and as i am leaving i notice what sounds like an exhaust leak under the hood. Come to find out not an exhaust leak as putting car in park and revving engine all was quiet. Then i noticed turning the wheels to the right stopped this noise. It literally sounds like an exhaust leak coming from under the hood. Also, my ABS light has since come on.
Apr 23, 2017 at 10:10 AM
HMAC300
  • 48,601 POSTS
what you hear as a leak my be a shield loose or broken or torque converter bolts loose, have a mechanic scan for code for the abs light to see what is wrong.
Apr 23, 2017 at 11:49 PM
DUSTIN BARNETT
turns out was driver side wheel bearing. Scuffed the rotor pretty bad when it failed. Changed the bearing now I have a constant thumping sound worse when turning right. Could this be that rotor even though it stays the same even when braking
Apr 25, 2017 at 11:17 AM
HMAC300
  • 48,601 POSTS
the brakes should have been redone because of the rotor problem it may be warped and check axle for being tight and no damage to that as well. also check wheel bearing on other side.
Apr 25, 2017 at 11:17 PM
