Suddenly car's exhaust is loud
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TEET333
My car was fine yesterday and when i started to drive today my car is loud. I'm pretty sure it is my exhaust. Because it just happened can I just mend it or do I need to replace the exhaust?
Jan 16, 2019 at 12:53 PM
  • 110,248 POSTS
Honestly, it matters what the cause is. If something has come loose, most likely it can, but most times rust is the cause. I attached a picture that shows the system from the engine to the tail pipe (picture 1). Inspect the system on your vehicle and let me know where the leak is located. If you want to replace the system, here are the directions.
____________________________________________
PROCEDURES
See picture 1
REMOVAL
Main Muffler
CAUTION: Before removing or inspecting the exhaust system, ensure that the exhaust system is cool enough.
1. Disconnect the main muffler from the center exhaust pipe.
See picture 2
2. Remove the rubber hangers and take out the main muffler.
Center Exhaust Pipe
See picture 3
1. Disconnect the center exhaust pipe from the main muffler.
2. After disconnecting from the front exhaust pipe, remove the center exhaust pipe.
Front Exhaust Pipe (including rear catalytic converter.)
See picture 4
1. Remove the front exhaust pipe from the center exhaust pipe.
See picture 5
2. Remove the front exhaust pipe from the exhaust manifold (Including front catalytic converter)
See picture 6
3. Remove the front exhaust pipe from the rubber hanger.
INSPECTION
1. Check the mufflers and pipes for corrosion and damage.
2. Check the rubber hanger and hangers for deterioration and cracks.
INSTALLATION
1. Temporarily install the front exhaust pipe (Rear catalytic converter assembly), the center exhaust pipe, and the main muffler, in order.
2. Install the rubber hangers so that they are identical (left and right) in length.
3. Tighten the parts securely, and then confirm that there is no interference with any body components.
______________________________________________
If you locate the leak, let me know where it is. Also, if you have other questions, let me know. I hope this helps.
Jan 16, 2019 at 1:00 PM
TEET333
Thank you. I will check it out.
Jan 17, 2019 at 2:53 AM
  • 55,732 POSTS
Please do we are interested to see what it is.
Jan 17, 2019 at 2:54 AM
