Exhaust
180,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
AMANDAFOWLE
Exhaust broke off at flange behind converter. Flange has been cut off, but there is not enough remaining straight pipe to get a good connection. Is it safe to cut the exhaust between the converter and rear 02 sensor so that we can run a straight pipe to reconnect the rest of the exhaust system? This would leave the converter but eliminate the rear 02 sensor.
Mar 3, 2016 at 1:26 AM
HMAC300
  • 48,601 POSTS
If you eliminate the O2 sensor it will set a code, try welding a piece of pipe to the converter or inside it to reconnect.
Mar 3, 2016 at 1:33 AM
AMANDAFOWLE
We do not have a welder handy and are trying to fix in a home garage. I realize that eliminating the sensor will send an error code to the computer, but will it affect the overall operation of the vehicle?
Mar 3, 2016 at 1:35 AM
AMANDAFOWLE
Below I have marked the section that I would like to eliminate from the exhaust system.
Mar 3, 2016 at 1:50 AM
WRENCHTECH
  • 20,760 POSTS
It really isn't that expensive to have an exhaust specialty shop do this for you. And then it's done right.
Mar 3, 2016 at 1:53 AM
HMAC300
  • 48,601 POSTS
wrench tech is right.
Mar 3, 2016 at 1:58 AM
