Exhaust
13,000,000 MILES • 2.7L • 6 CYL • 2WD
FREDRICK MONTGOMERY
What is it that when you start your car and it is filled with white smoke, but as you start the smoke goes away? it is driving normal. it is not overheating, but the check engine light is on.
Jun 4, 2016 at 8:29 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes and check your coolant level, it might be ahead gasket if fluid is low auto parts can scan for free.
Jun 4, 2016 at 8:38 AM
FREDRICK MONTGOMERY
I had it scan we read in cylinder 4. I change the coil then I took it back and change the plug, but it still doing the same thing.
Jun 4, 2016 at 8:42 AM
HMAC300
  • 48,601 POSTS
then you have a misfire your cheapest option is to go to a professional so he/she can freeze frame it as it may be a sensor that is messing up or causing the problem. you can check fuel pressure with a gauge as well auto parts rent it. if it is low that may do it as well.
Jun 4, 2016 at 9:15 AM
RENEE L
  • 1,260 POSTS
Hi Fredrick,
Here is a link to an article from this site that features written instructions and pictures showing and explaining the process of checking the fuel pressure yourself. If you decide you would like do this yourself you can purchase a fuel pressure gauge online from sites like Amazon.com.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jun 5, 2016 at 4:01 AM
