Occasionally when I want my car to be louder, I disconnect the back of exhaust from the h pipe?
50,000 MILES • 5.0L • V8 • 2WD • MANUAL
EDD5.0
Is there any real danger in doing so such as increased risk of carbon monoxide poisoning or anything else?
Jul 2, 2023 at 1:37 PM
  • 110,248 POSTS
All exhaust should exit past the body of the vehicle. In this case, that isn't happening. As a result, it does increase the likelihood of exhaust fumes entering the vehicle.
Let me know if that was what you meant or if you have other questions.
joe
Jul 2, 2023 at 3:26 PM
EDD5.0
Thanks. that’s what I figured but it should still be okay to run it like that, correct?
Jul 2, 2023 at 4:47 PM
  • 110,248 POSTS
That's a loaded question. LOL It won't hurt the vehicle, but it could hurt the vehicle. In PA, I have to fail a vehicle for state safety inspection if the exhaust exits the body and has no leaks. I'm not sure where you are located, but I would imagine it's the same.
If you do this, make sure to leave a window open just in case. However, I can't recommend doing it. I hope you understand.
Take care and Happy 4th!!!
Jul 3, 2023 at 2:20 PM
