excessive white smoke, uses too much fuel, transmission slips
180,000 MILES • 4.9L • V8 • 2WD • AUTOMATIC
DON DEAN HILL
  • 5 POSTS
white smoke, no overheating or coolant loss and gas mileage is bad. transmission slips at times taking off like a chugged.
Jan 11, 2017 at 6:38 PM
HMAC300
  • 48,601 POSTS
have coolant system pressure checked. this motor was famous for head gasket problems. check transmission fluid, if dark brown or black maybe needs a transmission overhaul. finally scan for codes.
Jan 12, 2017 at 12:19 AM
DON DEAN HILL
  • 5 POSTS
been done no leaks or overheating. uses about a gallon of gas a mile though. injector maybe?
Jan 12, 2017 at 12:40 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. See link.
Jan 12, 2017 at 2:01 AM
DON DEAN HILL
  • 5 POSTS
fuel pressure is 33 psi and when i disconnect the regulator it goes up about five pounds. no fuel smell from hose or regulator.
Jan 12, 2017 at 4:20 AM
JOHNNY G.JR
  • 320 POSTS
check your oil for residual gas fumes and its level.
Jan 12, 2017 at 6:18 AM
DON DEAN HILL
  • 5 POSTS
yes, the oil smells gassy, but is clear. i seam to have just noticed that i have quite a bit of blow by also.
Jan 12, 2017 at 6:58 AM
  • 55,658 POSTS
Hey Don,
Can you remove the radiator cap to see if there is pink goo inside? This will mean you have a radiator cooler that is blown. Also, can you pull the transmission dipstick to check the transmission fluid level please?
Please let me know what you find.
Best, Ken
Jan 12, 2017 at 8:33 AM
HMAC300
  • 48,601 POSTS
your fuel pressure should be 45-50 psi. so it is quite low but with the blow by do a compression test and if possible a cylinder leak down test.
Jan 12, 2017 at 8:38 AM
DON DEAN HILL
  • 5 POSTS
no pink in radiator fluid and trans fliud clean,i unhooked the modulator now it shifts right no slippingand also i checked each injector as it was running and all were ticking,but i did unhook the canister vent line at the lower front of the throttle body and it was wet and the rubber hose was melting,left it unhooked and ran for about 30 mins and smoke went away,then went to store tonight with 90 degree engine temp and smoke id back but looks grey now
Jan 12, 2017 at 2:23 PM
HMAC300
  • 48,601 POSTS
if you unhooked canister then the purge valve is shot and you have a vacuum leak if you didn' plug the line. I think your problems are deeper however.
Jan 12, 2017 at 11:04 PM
