Excessive oil use and Smell through Vent
100,000 MILES • V6 • 2WD • AUTOMATIC
ALTHAEUS
Oil leak on the left side, I cleaned it before and it has very slowly come back, I was told that the bolts down there are tighten enough so oil is coming through.
The smell started coming through after taking it to a mechanic and he did a standard service on it.
The smell is intermittent maybe happening once every few days and only smelt for a split second before disappearing again.
I have driven it 2000km and it is now needing a refuel on oil, dont know if thats normal
May 25, 2017 at 9:52 AM
  • 55,865 POSTS
It looks like from the pics that you have a valve cover gasket that is leaking and it needs to be replaced, here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/replace-valve-cover-gasket
Cheers, Ken
May 29, 2017 at 5:31 AM
