Interesting case, that noise has a metallic sound to it, like a bearing. Can you open the hood and rev the engine in Park and still hear the noise? Definitely sounds like a loaded bearing noise to me. If you can hear it with the hood open, and just raise the rpm in Park, I would remove the belt and see if the noise disappears, without the AC on its either the Alternator bearing or the Water Pump. If the noise is still present with the belt removed, then I would suspect a camshaft bearing.
I had a bad cam bearing once that sounded exactly like that, almost a belt noise, but it was in fact a camshaft bearing.
The belt on this vehicle has really tight tolerances. Never seen a belt with so many measurements involved.
As for the oil issue, if there are no apparent oil leaks, there is a very long Technical Service Bulletin on excessive oil consumption. If it's more than 1qt in 1,000 miles, it is considered very excessive and there is a very extensive cleaning process, or engine replacement. It looks to be an in cylinder issue with the oil consumption, Piston rings, Valve Stem seals. The TSB (pgs 10,11) is a very long TSB about each step taken depending on the test results out of a 3-step testing process. But it looks to be a dealership issue that the manufacturer is aware of for such a long TSB on oil issues. The bearing noise and oil issue might be related in this case, The last pg below is the Oil specs.
Images (Click to enlarge)
May 2, 2023 at 10:53 AM
