Excessive fuel consumption
250,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
MARK K PICTON
The vehicle used to get twelve to thirteen liters per 100 km which was great. It is now using twenty one to twenty two liters per 100 km; very bad!
I had a reconditioned gear box installed and had a lot of problems with the car loosing power and stalling immediately after, it was if fuel was not getting to engine. Used injector cleaner in fuel, changed plugs and leads and eventually car settled down but is now running very rich. I have taken car for analysis and there are no codes revealing any issues. When I first start car a black charcoal burn comes out exhaust as if fuel not burning correctly. Can you suggest possible issue?
May 18, 2017 at 11:50 AM
  • 55,748 POSTS
It sounds like you are having a problem with the MAP of MAF sensor which controls the amount of fuel that is used inside the engine. When these sensors go bad the computer sometime can not catch it.
Here is a guide that will help you replace the sensor
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Please let us know what you find ;)
Cheers, Ken
May 22, 2017 at 3:40 AM
MARK K PICTON
Thanks Ken. Pulled the MAP out and did MAP Sensor Test using multimeter and my breath. Sensor appears to be working at 0 in. Hg ... 4.67V and decreased as vacuum increased then increased to 4.67V as vacuum released.
2 Questions:
Is there anyway to clean MAP Sensor as appears to be sealed unit?
Even though appears to be working, considering its age and kms travelled, now that it is off would you recommend I replace it?
What else may be causing the excess fuel use?
May 22, 2017 at 12:57 PM
  • 55,748 POSTS
The map sensor does seem to be working and there is no need to clean it. A couple of things come to mind, first has the engine been tuned up lately? Next there can be a vacuum leak causing the problem here is a guide to help you find it.
and third is a plugged exhaust system mainly the catalytic converter. Here is a guide so you can test that as well.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 23, 2017 at 3:00 AM
