Excessive cranking before starting?
60,000 MILES • 1.5L • 3 CYL • TURBO • 2WD • MANUAL
MYFATHERSSON
  • 29 POSTS
My daughter's Mini One D had a load of error messages, MAF air flow too high, MAF air flow too low, Air intake leak, and Exhaust below efficiency.
I took the inlet manifold off and it was all gunked up due to the EGR, so I cleaned it up. I also capped the EGR pipe and cleared the codes.
It now cranks half a dozen times before firing. My daughter has driven it and the engine management light came back on.
This time, we had MAF air flow too low and EGR flow error. I took the cap off the EGR pipe, replaced the MAF sensor, and cleared the codes.
It still has excessive cranking, but I don't know if that engine light has come back on as I only did this on Saturday (15th).
When removing and re-installing the inlet manifold, I did have to unplug quite a few sensors so I wonder if it could be one of these that is the issue.
I would appreciate being pointed in the right direction.
Many thanks
Feb 17, 2025 at 8:56 PM
  • 55,688 POSTS
Sure, for heard starting I always begin with servicing the throttle body, this guide will show you how with instructions with the images below for your car.
Here is a guide for hard starting problems that can shine a light on the issue:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Feb 18, 2025 at 9:39 AM
MYFATHERSSON
  • 29 POSTS
Hi Ken,
I checked the throttle body, and it seems pretty clean.
I did notice from one of the links that you provided that if she had a Gen2 type throttle that you couldn't even disconnect it with the battery unplugged which I definitely did as I needed to get the wiring out the way.
When I first checked, it had 2 x MAF sensor air flow too low and 2 x MAF below efficiency. I removed these, did the checks and went for a test drive but so far, the codes have not come back but it may take a few days for that to happen.
I tried a relearning process that I found on the internet, but it hasn't made any difference.
Many thanks,
Kevin
Feb 22, 2025 at 1:41 PM
  • 55,688 POSTS
Yep, the turbo going bad can cause the high and low codes for the MAF. Lets remove the intake or exhaust pipe from it to check the endplay. Does the car have 60k on it? I would check the waste gate plunger as well.
https://www.2carpros.com/articles/how-turbo-chargers-work
Feb 23, 2025 at 2:16 AM
MYFATHERSSON
  • 29 POSTS
Hi Ken,
Sorry for the delay in getting back. I haven't had a chance to look at this yet because the car was in for its MOT. Whilst in there, they put their scanner on which must be a bit better than mine as it came up with some extra errors. I thought I would post them in case it helps.
I did try another camshaft sensor after seeing the camshaft error, but it made no difference.
The firs image is before removing codes and the second is the codes that reappeared.
Many thanks.
Mar 9, 2025 at 1:04 AM
  • 55,688 POSTS
Can I ask if you cleared the codes once the camshaft sensor was replaced, if not this must be done. Also, these codes are still leaning towards a bad turbo. Need need to do an inspection. Can I ask if you replaced the MAF sensor?
Mar 10, 2025 at 3:25 AM
MYFATHERSSON
  • 29 POSTS
Hi Ken,
I did clear the codes after replacing the sensor. I have also replaced the MAF sensor.
I will check the turbo out as per your instructions above and get back.
Many thanks.
Mar 10, 2025 at 6:47 PM
  • 55,688 POSTS
Sounds good, I think this is where the problem lies.
Mar 11, 2025 at 5:38 AM
MYFATHERSSON
  • 29 POSTS
Hi Ken
I finally got hold of my daughter's car for a bit and have taken the turbo off to inspect it.
I can see that there has/is some oil seepage into the air intake side. There also seems to be some lateral play and perpendicular play, best guess would be about 3/64 of an inch.
The good news is that I have at least sorted the excessive cranking, this was due to a sensor not being plugged in properly.
Many thanks
Kevin
Sep 6, 2025 at 1:04 AM
  • 55,688 POSTS
Hi Kevin,
Good find on that. 3/16 is too much endplay in the turbo shaft, I would get a replacement.
, Ken
Sep 6, 2025 at 9:12 AM
MYFATHERSSON
  • 29 POSTS
Hi Ken
Finally finished replacing the turbo and have been testing.
Had it idling for 20 minutes and it was OK, no engine management light. Drove it this morning and parked it up. Got back in, started it, and then about a second later, the engine management light came on.
The codes I got are;
P0101 - Stored - Mass or volume air flow sensor A circuit range/performance
P00BC - Pending - Mass or volume air flow A circuit range/performance air flow too low
P0101 - Pending - Mass or volume air flow sensor A circuit range/performance
Regards
Kevin
Sep 21, 2025 at 6:05 PM
  • 55,688 POSTS
There must be a leak between the MAF sensor and throttle body, I would remove the tubing and look for cracks, breakage. Does the engine idle okay? if so check the intake tubing, here is another method you might want to try.
https://www.youtube.com/watch?v=LRKWV4Are5c&t=95s&pp=0gcJCesJAYcqIYzv
Please go over this guide and get back to us.
Sep 22, 2025 at 5:05 AM
