Exhaust manifold gasket?
200,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
HIDDEN4321
  • 62 POSTS
I have found what looks to be a hanging piece of gasket at the bottom area of the manifold. Very loose hanging gasket like piece. The other side is off it looks like too.
Can that cause you to lose oil where it's not sealed?
What's the best technique to get off the bolts without breaking them? And do i use thread lock on new bolts and what's the torque?
Any info is appreciated.
Oct 26, 2023 at 11:50 AM
CARADIODOC
  • 34,415 POSTS
There's a metal gasket between the cylinder head and the exhaust manifold. It's actually in two pieces but they're held together with a connecting strip that doesn't get sandwiched between anything. If that connecting strip gets rusty and breaks free, it can hang down. If you can twist it to break it off, that part can be thrown away. If any of the sealing parts rust away, you'll have a loud ticking noise. That is especially easy to hear from inside during periods of moderate to heavy acceleration.
Chrysler doesn't use gaskets between the manifold and exhaust pipe. If you have to take that connection apart, you can expect the little tin clips that hold the nuts to break and let the nuts spin when you turn the bolts. Those clips are only meant to hold the nuts during assembly, then their job is done. It's hard to get a wrench on those nuts to hold them, and if you can, they're usually rusted too tight to spin them off with hand tools. It's much easier and faster to use an air-powered cutoff tool to cut through the bolts. The holes in the manifold are not threaded, meaning you can just lift out and discard the top parts of the bolts.
The exhaust manifold has nothing to do with oil leaks. The only thing going through them is exhaust gas. No thread locker is needed on any of these bolts. Using that will just make it that much harder to take them apart next time.
Oct 26, 2023 at 12:37 PM
HIDDEN4321
  • 62 POSTS
So, i shouldn't remove anything if there's no noise?
Where else other than valve cover gaskets-changed and put new on 2 months ago or oil pressure switch replaced recently new oil pan gasket, new rear main seal, can the small drip. seen at the bell housing and sometimes on oil filter end, be coming from? It's really going through oil a lot. but it's not easy to find where.
Is the gasket that's hanging down why at times i see white smoke. From tailpipe especially at start up or lights, but not always?
Oct 27, 2023 at 12:02 AM
CARADIODOC
  • 34,415 POSTS
Start by looking for the highest place you see oil. It's going to run down from the source of the leak unless the radiator fan blows it around.
When the source can't be located, there's a couple of things we do. One is to pressure-wash the area first, then add a small bottle of dye to the oil. After running the engine long enough, we search with a black light. The dye will show up as a bright yellow stain that can be followed back to the source.
The second method only works when the leak in at a non-pressurized place in the engine. That can include the valve covers, oil pan, and intake manifold. Oil will splash around those areas and leak out even after the engine is stopped. For those types of leaks, we can use a smoke machine to inject a white, non-toxic smoke at 2 psi, then we watch for where it sneaks out. That usually doesn't work when the leak is in a pressurized passage. Oil leaks from those places only while the engine is running.
When the leak is from a non-pressurized area, it can be worsened by a defective or plugged PCV valve. That can prevent fumes from getting collected and burned, and will allow excessive pressure to build up. That pressure will help push oil through a leak.
Oct 27, 2023 at 11:01 AM
HIDDEN4321
  • 62 POSTS
It has dye in it and over the last 2 weeks haven't been able to find leak.
I will recheck with the blacklight from the top down. New PCV valve. will a compression check or looking at spark plugs tell me more?
Oct 27, 2023 at 12:33 PM
CARADIODOC
  • 34,415 POSTS
You're buzzing off into totally unrelated areas. A compression test can tell you if compression is low, but another test, (cylinder leakage test), is needed to figure out where the compression is being lost. One of the four possibilities is worn piston rings. That can cause excessive oil consumption, but that will not cause leakage outside the engine. The symptom would be blue smoke out the tailpipe.
Same for the spark plugs. There shouldn't be any oil in the cylinders. If a cylinder head gasket is leaking between a cylinder and an oil drain back passage, that too would cause oil to be burned and go out the tail pipe, but it wouldn't be leaking outside.
Oct 28, 2023 at 10:20 AM
HIDDEN4321
  • 62 POSTS
I also wanted to know if the o ring on the cam pos sensor can factor leakage? I'm goanna replace oil drain plug since its cheap an i see a tad there. Also, see a tad ar lower lip of oil pan at rear and some more along bottom of bell housing. I'm stumped.
I did find a rad hose from the heater core needs retightening leakage..
I don't know what to look at next.
Added 3/4 of a quart today .2 weeks ago was full...
Any other suggestions?
Oct 28, 2023 at 1:42 PM
CARADIODOC
  • 34,415 POSTS
The camshaft position sensor is inside the distributor. There is a large O-ring right under the base where it sits on the engine block, but leakage there is very uncommon. Oil there is not under pressure. It would have to splash up there, then get pushed out by excessive crankcase pressure before it runs down into the oil pan. More likely a film of oil would settle around the distributor if that O-ring wasn't sealing properly. If enough oil leaked out there to cause a drip, the PCV valve would be the better suspect as it isn't allowing the normal blowby gases to be drawn out and burned. That results in pressure in the crankcase that will push oil and / or air out through a leak.
The oil pressure sending unit sits right beside the distributor. There is pressurized oil there. Just about the only time you might find oil leaking past the threads is right after a new sensor is installed. Oil won't start leaking there years later. It is possible for the sending unit to leak internally. The two clues there are the entire sending unit will be wet, all the way up to the connector, and, if you pull the connector off, you'll find oil down by the sensor's terminals. The connector has a rubber weather seal to keep water out, so if you do find oil in there, it can only come through a leaking sensor.
Oct 29, 2023 at 10:48 AM
HIDDEN4321
  • 62 POSTS
Is this normal on start up an as it continues to run..
Oct 31, 2023 at 4:18 AM
CARADIODOC
  • 34,415 POSTS
One of the byproducts of a properly working catalytic converter is water vapor. When the exhaust system is still cold, that water shows up as steam from the tail pipe. There will also be a small drain hole at the rear / bottom of the muffler. You're likely to see water dripping from that hole too. That steam can also be due to heating up the condensed water vapor that was pooled in the exhaust system overnight. That will burn off within a few minutes. As the exhaust system gets hot, you'll see less and less of that steam coming out of the tail pipe.
If that white smoke continues or becomes worse the longer the engine runs, that is a sign of burning antifreeze in the engine. That's caused by a leaking cylinder head gasket. That can happen to any engine, but it isn't real common with the 3.9L. The first clue is the level will drop over time in the coolant reservoir and you'll have to add periodically. There is an additional chemical test that can be performed to identify that. If you don't have to keep adding coolant, consider the smoke out the tail pipe to be normal. Coolant at the tail pipe will also have a sweet smell to it. Hold your hand there to collect some of the vapor. if it's water, it will evaporate cleanly. If it's antifreeze, it will leave a slimy, oily feeling.
Oct 31, 2023 at 8:22 AM
HIDDEN4321
  • 62 POSTS
Okay, I will get that chemical test thing to test for gasses in radiator fluid.
Oct 31, 2023 at 10:35 AM
CARADIODOC
  • 34,415 POSTS
Only do that if you've been having to add coolant. This link is to an article that shows how it is done:
You can usually borrow the tester from an auto parts store that rents or borrows tools. In my city, they make you buy the tool, then you get a full refund when you return it. If you choose to keep a tool, you still return it, then they give or order you a brand new one.
In this case they are likely to make you buy your own bottle of special fluid. That is because it is rendered ineffective if it freezes or if it becomes contaminated with coolant. They don't want to risk giving you bad fluid that was ruined by the previous person, so they made him buy his own bottle too.
When you do this test, keep an eye on the coolant level in the radiator. You may need to drain some out before you start, plus, it is going to expand a lot as the engine warms up. Drain more out as necessary. Air from on top of the radiator is the only thing that must get sucked into the tester.
Oct 31, 2023 at 10:48 AM
HIDDEN4321
  • 62 POSTS
I did the test, and it remained the blue color. what should i look at next? plugs and compression.
Going to throw a new drain plug on and look around again for a leak but i think it's being burned. Wondering if the plenum gasket is leaking it. What test do I do on the Plenum? I covered the hose to PCV fully and checked other side breather tube from valve cover and no suction.
Is there a test for valve stem seals to detect leaking?
Nov 4, 2023 at 1:39 PM
CARADIODOC
  • 34,415 POSTS
Leaking valve stem seals used to be rather common years ago, but not so much today. Oil that runs down the stem into a cylinder gets burned so slowly that you'll never see it once the engine is warmed up. It's when the engine is still cold that oil that ran down overnight pools on top of a piston, then goes out the tail pipe and is seen as a dark blue cloud. That gradually clears up in a few minutes. I've had a few engines with that problem. None of them used oil fast enough that I needed to add between oil changes. When I pulled the engines apart, I found the seals to be badly hardened and they had cracked apart. If your seals are badly worn but not cracked, I don't think you're going to lose enough oil to worry about. It's the blue smoke when starting a cold engine that is the only symptom.
If you have an original drain plug, it will have a built-in rubber gasket. Believe it or not, those are almost fully tightened with finger pressure. A very slight tug on the wrench is more than sufficient to make them fully tight. If one has been overtightened, the threads will start to peel. You may see part of a thread hanging from the drain hole when the plug is removed. At that point the plug must be replaced or it likely will work loose or can't be tightened sufficiently. In real bad cases, it is possible to create a crack on the oil pan around the drain hole. For my own vehicles, I've had good luck sealing up things like that with Chrysler's gray RTV gasket sealer. With their black stuff, it stays a little more rubbery, but it absolutely will not bond or seal through the slightest film of oil. Everything has to be washed or sprayed down with Brake Parts Cleaner or something similar, and dried well, then it might work. The gray sealant WILL bond through a light film of oil and it cures a little harder. This is not a way I'd repair a customer's vehicle as it risks leaking again, but I would try that first on my own stuff. The alternative, if there's a crack in the pan, is to replace it.
For the intake manifold, there's two places oil can leak. One is at the front or rear on a V-type engine. The oil isn't under pressure there, so there will only be minor seepage unless the PCV system isn't working. The second place is when there's oil drain back passages running through the intake manifold and the gasket is leaking. That oil typically gets sucked into an intake passage and goes directly into one or two cylinders. That will be a major loss of oil and it WILL make a blue cloud out the tail pipe even when the engine is warmed up. This is usually seen on four-cylinder engines as they do have drain back holes running through the cylinder head. Your 3.9L is a version of the really rough and reliable 318 c.i., with two cylinders lopped off. There's no pressurized oil running through the intake manifold, so that major leak isn't possible. The oil in the drain back holes is under no pressure. The oil in the other passages is at around 45 psi. Those passages are not close to the intake passages in the cylinder heads, so it's very unlikely there would be oil loss there. A lot of gasket would have to corrode away, then the very high pressure in the cylinders would push combustion gases into the oil system long before any oil would flow the other way from the low pressure to the high pressure area. None of these things would cause leaking oil to be seen on the outside of the engine. Anytime pressurized oil gets sucked into the intake manifold, there will be no mosquitos in your neighborhood for miles around! When you remove the spark plugs, those for the cylinders sucking in oil will be coated with black soot. If it's bad enough, that will lead to spark-related misfires.
Nov 4, 2023 at 4:50 PM
HIDDEN4321
  • 62 POSTS
I did a quick compression test with all very loose if not even in 1st tgread..and most read 150 PSI 1 other was 148 and 146 beside it. i didn't keep a long turn over time nor opened the throttle. Is this good?
I also saw gunk on a few plugs but I'm not sure if it is additive or suit or what..
Nov 9, 2023 at 1:06 AM
HIDDEN4321
  • 62 POSTS
And i can't find dealer PCV, discontinued when i called. What's the best option?
Nov 9, 2023 at 1:15 AM
HIDDEN4321
  • 62 POSTS
Can this one for a 01 ram 5.2 work on PCV 5175352aa.
Nov 9, 2023 at 6:48 AM
CARADIODOC
  • 34,415 POSTS
I found different part numbers for the two applications. They look quite different too. I use the Rock Auto web site when researching which parts interchange.
Nov 9, 2023 at 9:00 AM
