Can I crank the engine with exhaust off the car?
1,000,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
BRIAN CHILDRESS
  • 19 POSTS
I just had my transmission changed and I want to know if they can crank, and test drive it without the exhaust because I forgot to take it with me to the shop.
Nov 21, 2021 at 11:26 PM
SQM
  • 6,383 POSTS
Is the exhaust manifold still on the car? Are you just missing the exhaust piping?
You can drive without the exhaust pipe, but it is not ideal, and you do not want to drive it for an extended period of time.
If you are missing the exhaust manifold, I would advise against driving it.
Let me know of any questions.
https://www.2carpros.com/articles/how-exhaust-systems-work
Nov 22, 2021 at 12:37 AM
STEVE W.
  • 15,413 POSTS
They can but it will be loud. It may set a couple of O2 sensor codes as well because they won't be working. Those should clear themselves as soon as it's back together though. I wouldn't drive it a lot though as it will also be dumping the exhaust right below the cabin and could cause bad things to happen to the driver, as well as getting a ticket or two if the police catch it. The shop may not want to drive it for those reasons though.
Nov 22, 2021 at 12:39 AM
