Amazing. Pads, Shoes , calipers and wheel cylinders are all normal, no leak. the only thing is- red break light is on. Any advice?
Feb 28, 2015 at 3:43 PM
CARADIODOC
✓Experienced Mechanic
Check the brake fluid level in the reservoir. If it's low and there's no leak, the front pads are worn to the point of needing to be replaced.
Pull up on the parking brake pedal. If the light goes out, suspect a stretched cable or one of the rear ones is rusted in the partially-applied position.
