Everything works fine, just red brake light is on on cluster.
2000 CHEVROLET ASTRO
220,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
AJ4REPAIR
Amazing. Pads, Shoes , calipers and wheel cylinders are all normal, no leak. the only thing is- red break light is on. Any advice?
Feb 28, 2015 at 3:43 PM
CARADIODOC
  • 34,369 POSTS
Check the brake fluid level in the reservoir. If it's low and there's no leak, the front pads are worn to the point of needing to be replaced.
Pull up on the parking brake pedal. If the light goes out, suspect a stretched cable or one of the rear ones is rusted in the partially-applied position.
Feb 28, 2015 at 3:47 PM
