everything dies after turning key
100,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
NATER81309
My problem started after I let my car sit for three days with no use. By then, the car battery was drained, so I had to push-start it, and it worked. Soon after, rain came, and the roof was not on, and of course, the battery was dead again. This time, I had jumped started it to put into the garage, but then all of a sudden the car's battery voltage gauge started to overcharge and went up to 19 on the red once I parked it and turned it off I tried to turn it on again, then once I turn the key I got one click and then the power cuts off, so I thought it was just because of a dead battery, so I left the battery charging with the tender. Came back and still no power, but I then disconnected the negative terminal and reconnected it, power came back, so I tried to crank it, but then the same thing happened, I got one click and then the power cuts off. I honestly don't know what it is, and I need this car for school. Any help would be appreciated. Thank you.
Sep 23, 2025 at 8:10 AM
STEVE W.
  • 15,410 POSTS
OK the click and die sounds like you have a bad connection in the power feed. First I would get a new battery, modern batteries don't like to be left dead at all, and try to avoid using the vehicle to charge one that is that far discharged. Now as removing the cable reset the system, I would start by cleaning the cables at both ends, then check the body and chassis grounds for corrosion. Clean those as well. Now in theory a Jeep is supposed to be tough enough to run with the roof off in the rain, but they still have issues with the grounds like every other Chrysler product. Whet they do is take 5 wires or more, crimp a single ring terminal on the end and call it done, the problem is that moisture gets into the gaps between the wires and corrodes them, the connection can look perfect outside but be corroded enough that it doesn't actually work. On your Jeep the main grounds are from the battery to the engine block and from that same ground point to the interior systems. As such the battery and that ground would be the first stop. Then the battery positive to the starter motor and to the power distribution center main connection.
Sep 23, 2025 at 5:13 PM
NATER81309
Thank you, ill look into it and update you.
Sep 23, 2025 at 9:05 PM
STEVE W.
  • 15,410 POSTS
It is unfortunately a common theme with them once they start aging. Normally if you find one that is becoming an issue you will find others are as well. Typically I remove the bolt or nut, cut off the factory crimp and clean each wire than put 2 together and crimp them into a new ring terminal that has heat shrink with sealer on it. Then clean off the area, put them back together and then coat the spot with dielectric grease to keep the air out.
Sep 24, 2025 at 2:38 AM
