Hard starting in the mornings
2010 FORD EVEREST
89,000 MILES • 3.0L • TURBO • 4WD • AUTOMATIC
MEGAN20
Everest won't start in the mornings, motor is turning but not going. Also glow plug are in working condition went for a service yesterday so everything is ok
Jul 29, 2014 at 5:19 PM
  • 31,937 POSTS
This sounds like it could be the engine coolant temperature sensor which needs to be replaced but to be sure here is a guide to help us fix the problem
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Aug 2, 2014 at 12:58 PM
PENNJAM74
The coolant sensor fixed my issue cost me $56.00 this site rocks!
Dec 19, 2019 at 6:48 AM
TOTO509
Hi guys,
I have a very big Problem with my Ford. Each times I turn it off, it is very hard to restart it. Someone told me that I have injector problem. Another one told me that I have compression problem. Now I know what to do. I have some DTC too: P0335, P0193 and P0406. Please let me know what you think guy.
Thank You.
Dec 19, 2019 at 6:48 AM (Merged)
HMAC300
  • 48,601 POSTS
there is no code 0335 but one of htem is maybe a damaged fpr sensor meaning fuel rail sensor and the other is egr problem so check for a clogged egr or shorted wire or an eger sensor
TOTO509
The scanner that I used said that P0335 is "crankshaft position sensor A circuit". When it start, there is no loss of power. I already cleaned the egr sensor. I would like to what exactly cause my car to not starting.
HMAC300
  • 48,601 POSTS
if I were a magician I could actually wave a wand and it would start. but i'm not I cant' give an exact cause. we dont' have that car in the u.s. and hence not that code either. but check resistance of crank sensor against a new one aswe don't have that info avialbale to us. finally try resetting your security system that may be the cause if it take s a long time to start as well as check yor fuel pressure with a gauge it may below causeing this.
KRIS509
The car starts very hard. A mechanic told me that I have a problem with compression. But the car is running well. No loss of power. The only problem is the START. I notice a little oil in the turbo, the intercooler and in the EGR valve. I have some error codes. P0335, P0406 and P0193. Another mechanic had previously told me that I had injectors problems. I do not know what to do now.
Please give me and advice
  • 110,240 POSTS
I don't think there would be a compression issue with such low mileage. As far as the codes,
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0406 EGR Sensor A Circuit High Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
Have any of these items been checked?
TOTO509
Thx for answering so quickly
TOTO509
I noticed that I had an oil leak coming from the turbo and from the egr valve.
What you think it can be? Can it prevent the engine from starting?
HMAC300
  • 48,601 POSTS
if yu have an oil leak at turbo then it cold possibly get into your exhaust which going through the egr would carbon it up and clog it but you said you already checked the passages. it may make it hard to start but I think your problem has to do with something else like electrical or fuel pressure.
ICYBLU
I got the same exact problem with this. Ford everest 2008. The only different is i dont have any DTC (or maybe my aftermarket scanner can't read it).
What i have done are:
- overhaul the engines since there's some loss compression
- change the fuel rail
- clean the egr
Some people advice me to change the injector and the fuel supply pump. But they can't be sure that it will resolve the problem.
So may i know if your car have been fixed? what caused it? And can we make sure if the problem is from the fuel supply pump or the injectors by testing them somehow?
HMAC300
  • 48,601 POSTS
repost this question
ACEVERGEL
My ford Everest is very hard to start every morning? And some noise during starting, and my car is already 5 year this coming may 1, 2014 and another problem is rear wheel very noise during I;m rough road
HMAC300
  • 48,601 POSTS
have the wheel bearing checked for wear, scan for codes and check fuelpressure with a gauge auto parts rent them
