How to remove the evaporator valve?
164,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
JELLENTZ
I need to change the evaporator valve do i have to remove the dash if so, where can I get directions?
May 12, 2023 at 2:56 PM
  • 110,248 POSTS
Do you mean the expansion valve or the evaporator core?
May 12, 2023 at 3:39 PM
JELLENTZ
expansion valve. Thanks, John
May 13, 2023 at 4:11 AM
  • 110,248 POSTS
That makes sense. LOL If you look below, I attached the removal and installation directions specific to this vehicle.
Take a look through the pics below and let me know if you have questions.
May 13, 2023 at 3:44 PM
JELLENTZ
Just want to make sure I can replace the valve under the hood without removing the dash on the 2006 Pacifica.
May 14, 2023 at 2:38 AM
JELLENTZ
When my son put in the new compressor, he used pag 46 oil after that we saw use nd-8 pag. will this cause problem? John
May 14, 2023 at 3:22 AM
  • 110,248 POSTS
The oil wouldn't have hurt it. They are basically the same thing. And yes, you can replace the expansion valve from under the hood.
Let me know how things work out for you.
May 14, 2023 at 12:42 PM
