Where is the EVAP vent sensor located?
115,000 MILES • 2.0L
CPERRY54
  • 35 POSTS
Having a problem with the Evap vent sensor, and where is it located?
Feb 26, 2022 at 7:57 AM
SQM
  • 6,383 POSTS
The EVAP purge solenoid is located under the hood, on the right side of the engine (if you are facing the engine).
I have attached diagrams below for your reference.
https://www.2carpros.com/articles/evap-system-code-repair
Feb 26, 2022 at 9:01 AM
CPERRY54
  • 35 POSTS
The vent valve is it on the evap,? If so where is it located?
Mar 3, 2022 at 8:45 AM
SQM
  • 6,383 POSTS
The EVPA canister is located on the top of the fuel tank.
See attached diagram.
Mar 3, 2022 at 2:54 PM
