Code p0446 system vent control circuit?
83,000 MILES • 2.6L • V6 • 2WD • AUTOMATIC
DEQUESO
  • 38 POSTS
I have replaced the purge valve, also canister vent valve and gas cap. Drive 90 miles same code returns I clear code drive around 70 miles code returns etc, etc. I have checked the electrical connections all good.
Sep 20, 2023 at 7:33 AM
  • 55,770 POSTS
Here is the definition of the code and this problem occurs when the EVAP purge solenoid goes out.
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction
Here is the location of the EVAP purge solenoid #13. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 21, 2023 at 7:07 AM
DEQUESO
  • 38 POSTS
I have replaced that solenoid plus canister vent valve also gas cap, have checked the electrical on the solenoid and wire conn all good. If I have a leak, why would it be so erratic? Plus, what does it hurt if it leaks???
Sep 23, 2023 at 2:06 AM
  • 55,770 POSTS
This is a circuit code which means the valve is bad, the wiring or the PCM. It does really hurt anything except for having the check engine light on.
Sep 24, 2023 at 3:04 AM
