I just need to know where this is located so I can see if I can change it.
Mar 26, 2025 at 2:26 AM
✓Experienced Mechanic
Sure, the EVAP purge solenoid is located under the hood on the engine intake manifold. Here is the location, be sure to clear the codes once the valve has been replaced. Check out the images (below).
