Hole in EVAP line
80 MILES • 3.6L • V6 • 4WD • AUTOMATIC
DAVID HEBNER
My EVAP line has a pinhole in it and the part is going to take months to get here.
Is there a temporary fix?
Nov 19, 2018 at 6:36 AM
  • 110,248 POSTS
Honestly, the pressure in an EVAP hose is minimal. If you have located the hole, try using an automotive grade epoxy to seal it.
Also, in most cases, a small EVAP leak will not affect the performance of the vehicle.
If possible, let me know what code was set so I can get a better idea where in the system it may be located.
Nov 19, 2018 at 11:22 AM
