Evap leak
130,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DAD2CAMRIN
  • 6 POSTS
I'm performing my own EVAP test. I plugged the smoke into the brake booster hose and blew in it and smoke came out my air-box on the other side. why?
Oct 23, 2019 at 10:13 AM
DAD2CAMRIN
  • 6 POSTS
Engine light come on so I use my code reader and that said I had a small EVAP leak. so I replaced the vent valve solenoid and a new gas cap and it still didn't fix the problem.
Oct 23, 2019 at 10:20 AM
  • 110,248 POSTS
Welcome to 2CarPros.
A small leak can be at any point in the EVAP system and often times are nearly impossible to find.
What I suggest is this: Anytime I have such an issue, I don't even bother trying to find it without using a smoke machine. Basically, smoke is injected into the EVAP system at a very low pressure. When it reaches the leak, you will see where it is coming from.
Oct 23, 2019 at 1:39 PM
DAD2CAMRIN
  • 6 POSTS
Instead of trying to enter the smoke at the brake booster should I try to enter the smoke at the port that's just above the intake manifold on the drivers side? Usually with like a green cap or something like that?
Oct 23, 2019 at 2:32 PM
DAD2CAMRIN
  • 6 POSTS
Should I just try to replace most of the EVAP line system with like a black gas line hose in place of the steel line because some of the line I have now is rather rusty?
Oct 23, 2019 at 2:35 PM
DAD2CAMRIN
  • 6 POSTS
Po442 was the code that came up, small EVAP leak . What other place other than the brake booster hose should I hook the smoke machine up to?
Oct 23, 2019 at 7:44 PM
DAD2CAMRIN
  • 6 POSTS
Where is the port that I hook up the smoke machine too for a small EVAP leak?
Oct 24, 2019 at 4:17 AM
