Had a code P1401 so I replaced the EGR pressure sensor which cleared the light. Few days later I got a code P0401 for insufficient flow. The 2 hoses from the sensor had deteriorated and pieces clogged up the pipe they connect to. Cleaned that out and code cleared but now I have a noise like a howl in my air box area and the hose from the evap system to the back of throttle body collapses. Could it be the EGR valve itself? Let me add I’d removed EGR valve and the ports were completely clogged up solid and I did clean it all out. I have pictures below of before and after. Thanks
Jan 13, 2020 at 9:16 PM
