EVAP Fuel Tank Pressure sensor location and replacement
130,000 MILES
MSOLIMAN85
  • 7 POSTS
where is the the EVAP Fuel Tank pressure sensor located in the vehicle listed above? How can I change it?
Thanks
Jun 20, 2019 at 4:03 PM
KENW1
  • 213 POSTS
Welcome to 2CarPros.
It is located on top of the fuel tank sending unit. Replacement requires dropping the fuel tank. It can be accomplished with a floor jack and jack stands.
1 Jack up rear of vehicle and secure with jack stands.
2. Relieve fuel pressure by depressing schrader valve on fuel rail.
3 Place jack under tank.
4. Remove fuel filler and overflow hose clamps.
5. Remove bolts securing tank straps.
6. Lower tank and replace sensor.
Below is a picture of how it mounts.
Jun 20, 2019 at 4:36 PM
