carrier bearing?
100,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
LUK2OR3
  • 23 POSTS
How to tell if it's u joint or carrier bearing?
Apr 10, 2021 at 7:24 PM
  • 110,248 POSTS
First, a bearing will usually make a howling noise when moving. Most times, a bad u-joint will cause a vibration or banging sound when you shift into gear.
If you take a look through this link, it explains how to test a universal joint.
https://www.2carpros.com/articles/how-u-joints-work
As far as a carrier bearing, you are more likely to heat it. Also, not always, but most times there will be a leak at the differential seal where the drive shaft and carrier connect.
Let me know if this helps.
Apr 11, 2021 at 1:23 PM
LUK2OR3
  • 23 POSTS
The differential is on the other end. do you mean where the shaft of small driveshaft meets transmission?
Apr 12, 2021 at 4:58 PM
  • 110,248 POSTS
We are thinking of two different things. The carrier bearing I'm referring to is in the differential. Are you referring to the output shaft on the transmission where it connects to the driveshaft? Is there any trans fluid leaking from the seal?
I read my first post again. I meant to say you will usually hear (not heat) a bearing problem. They usually make a howling sound.
Apr 13, 2021 at 11:09 AM
LUK2OR3
  • 23 POSTS
My truck makes a low pitch noise more noticeable sound wise at lower speeds when I take my foot off the gas it goes away and it seems like a loss just a little bit of horse power. no clanking noise or vibration.
Apr 14, 2021 at 12:20 PM
LUK2OR3
  • 23 POSTS
I have a4.3ls and 2 piece driveshaft.
Apr 14, 2021 at 12:23 PM
LUK2OR3
  • 23 POSTS
I have a4.3ls and 2piec drive shaf.
Apr 14, 2021 at 12:24 PM
  • 110,248 POSTS
If there are no clanking or vibrations, chances are it isn't a universal joint. As far as the center support bearing, is there any up and down or side to side play?
Apr 14, 2021 at 1:19 PM
LUK2OR3
  • 23 POSTS
Yes I can push it up. It's resting on the bottom rubber the bearing and has about a half inch gap at top.
Apr 14, 2021 at 1:45 PM
LUK2OR3
  • 23 POSTS
And do you have step by step instructions? unless it is something else.
Apr 14, 2021 at 1:47 PM
LUK2OR3
  • 23 POSTS
Other than center bearing.can I jack rear off ground and run truck and see where noise is coming from?
Apr 14, 2021 at 1:49 PM
LUK2OR3
  • 23 POSTS
Is there any chance it is transmission mount? it looks like a little separation between the rubber and metal on mount.
Apr 14, 2021 at 1:55 PM
  • 110,248 POSTS
It certainly can be a transmission or motor mount. Can you upload pics of what you are seeing? Also which directions do you need?
As far as lifting the rear to check where the sound is coming from, just make sure it is safely lifted. I wouldn't recommend getting under it for inspection.
Let me know what you find.
Apr 15, 2021 at 9:44 AM
