Evaporator code P0441 and code 13
177,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
KEN9477
My vehicle is throwing codes p0441 and code 13. I have replaced several hoses under the hood and I am not sure if it is the evaporator canister, or hoses to it. The evaporator canister is located by the drivers side rear tire.
Oct 26, 2016 at 4:44 AM
HMAC300
  • 48,601 POSTS
441 deals with evaporator purge solenoid. take it off and inspect vacuum line for rip/tear etc. also, check for junk in line. if line is bad replace it. tap solenoid on a flat surface if junk comes out replace canister and solenoid then clear code.
Oct 26, 2016 at 5:12 AM
HMAC300
  • 48,601 POSTS
code 13 is for re-circulation motor not working for heater/air conditioning. see picture for diagnosis.
Oct 26, 2016 at 5:16 AM
