Evap Code 0443
124,572 MILES • 3.6L • V6 • 2WD • AUTOMATIC
KINGMURPHY00
Just bought the car listed above, engine light is on. When OBD is read it says (P0433 Evaporative Emission System Purge Control Valve Circuit) I have changed fuses, bought a new gas cap, and replaced the purge control valve. I can hear the purge valve ticking as it should, I have erased the code and it comes back the next time the car is turned off and restarted.
Any suggestions?
Oct 16, 2021 at 5:04 AM
SQM
  • 6,383 POSTS
Keep in mind that sometimes the issue is due to the electrical circuit for the valves.
https://www.2carpros.com/articles/evap-system-code-repair
I have attached the troubleshooting steps below. It could help you with the diagnostics.
Oct 16, 2021 at 7:51 AM
KINGMURPHY00
Okay, thank you for the quick response.
Oct 17, 2021 at 7:41 AM
SQM
  • 6,383 POSTS
You are welcome.
Oct 17, 2021 at 8:21 AM
