i cannot put gas in the tank
205,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
DTOMMASONE
  • 5 POSTS
cannot put fuel in car. I have replaced the tank pressure sensor and filler neck. I still have the same problem.
Nov 25, 2016 at 8:15 AM
WRENCHTECH
  • 20,760 POSTS
If the canister vent valve is stuck closed it will do that. It is located behind the left rear wheel well. https://www.2carpros.com/images/external/86452774.gif
Nov 26, 2016 at 1:04 AM
DTOMMASONE
  • 5 POSTS
I have even cut the two lines that go to the canister and I still have the same problem. I basically bypassed the canister and canister vent valve. I am thinking it is the valve at the top of the tank that is to the right of the pump it has two lines to it and no electrical plug. I think it is another vent valve.
Nov 26, 2016 at 3:12 AM
WRENCHTECH
  • 20,760 POSTS
The tank is a sealed system. It has no other vents. It can only be something restricting the filler pipe at this point. It likely has a rollover ball in the filler.
Nov 26, 2016 at 3:14 AM
DTOMMASONE
  • 5 POSTS
I replaced the filler neck and there was nothing in the neck. could the ball be in the tank right at the opening were the filler neck attaches? what is the thing on the top of the tank that I was telling you about?
Nov 26, 2016 at 3:22 AM
WRENCHTECH
  • 20,760 POSTS
I do not think that was a valve. It is just hose connectors.
Nov 26, 2016 at 3:27 AM
DTOMMASONE
  • 5 POSTS
what about the check ball? is it in the tank were the filler neck attaches? because I put a new filler neck on and there was no check ball in the assembly.
Nov 26, 2016 at 3:51 AM
WRENCHTECH
  • 20,760 POSTS
I do not know. Stick something down there and find out.
Nov 26, 2016 at 3:53 AM
DTOMMASONE
  • 5 POSTS
thank you for your insight and help.
Nov 26, 2016 at 4:07 AM
CJ MEDEVAC
  • 11,000 POSTS
Have you taken it loose at the tank?
Do nit know your rig's specifics
I took pictures of my brother-in-law installing a new fuel pump.
1) This is a Tahoe
2) These are the Fuel filler hose and the fill vent hose (lets air out of the tank while fuel takes it is space)
3) Hoses removed, See the blue fitting? It has a screen on it.
You cannot see it but the fill hose fitting (The big hole). Also, has a grid or screen in it too. The squares in it were larger than the blue fitting. My hypothesis is this is an anti-somebody sucking your fuel out prevention measure.
Imagine somebody eating a Little Debbie oatmeal cream pie (or two) then stuffing the wrapper(s) in your fuel neck.
first fill up afterwards might shove the wrapper on down and it now mostly covers the grid.
Just a thought, this may not be your answer either. But it would be an easy check!
The Medic
Nov 26, 2016 at 8:30 AM
