Shaking and engine light on
180,000 MILES • 2.0L • 4 CYL • AUTOMATIC
DAWN MARIE2
I have replaced spark plugs and wires. Ignition coil as well as O2 sensor. The car seems to run worse than ever now. Shakes bad, shuts off when going in reverse.
Jun 12, 2018 at 10:26 AM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com
Before I try to help, can you let me know what trouble codes are in the computer at this point? Many things can cause this problem, vacuum leaks, plugs not properly gaped, mixed up spark plug wires.
Let me know so I can better guide you.
Jun 12, 2018 at 12:31 PM
