No reverse when transmission is hot?
2007 CADILLAC ESCALADE ESV
165,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
JPHILLIPS435
All gears work fine drive is working fine. The manual part is working fine also but after driving the vehicle for a little while when I go to put it in reverse, there is a very long delay and sometimes it will slowly start working but today it did not work at all. Any help would be greatly appreciated.
Nov 9, 2022 at 7:34 AM
  • 110,240 POSTS
The first thing I would ask is if the transmission fluid level and condition have been checked. If you haven't, that is where I would start. It could be low on fluid.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Also, if the check engine light is staying on, have the computer scanned to see if there are any codes related to the transmission. Most parts stores will do it free of charge.
What you described sounds like either a fluid issue or a line pressure issue. Has the transmission been serviced over the years? A partially plugged transmission filter can lower fluid pressure. Also, there are pressure solenoids can fail. That is why I'm recommending having the computer scanned.
Nov 9, 2022 at 11:35 AM
