ESC module code
20,000,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JOSHBASLER 808
  • 14 POSTS
I am getting a ESC module code but it is new computer is new all sensors are new. It will run okay and sometimes it surges while under acceleration was really bad unroll. I changed computer now it fairly happens and only for a second, but still cannot get rid of the ESC module code.
May 3, 2018 at 3:09 AM
Good afternoon.
What is the code?
I need that to help you with this issue. There is a ESC module by the throttle body but need to confirm the failure.
May 3, 2018 at 6:25 AM
Here is a picture for you of the wire diagram for the circuit.
Check the fuse listed for power on both sides.
May 3, 2018 at 6:27 AM
JOSHBASLER 808
  • 14 POSTS
Code 43.
May 3, 2018 at 7:16 AM
Information for you.
DESCRIPTION AND OPERATION:
The Knock Sensor (KS) system has a module that sends a voltage signal to the ECM. As the KS detects detonation, the voltage from the KS module to the ECM will drop. This signal allows the ECM to retard timing. The ECM will retard the timing when knock is detected and rpm is above 900 rpm. Diagnostic Trouble Code (DTC) 43 will set when the ECM has detected low voltage at CKT 457 on terminal "B7" for longer than 5 seconds with the engine operating or when the system has failed the functional check. The ECM continually monitors voltage on CKT 457 on terminal "B7."
The ECM will advance the spark timing when:
^ Engine coolant temperature is above 95°C.
^ Engine is under heavy load (near WOT).
test chart
CHART TEST DESCRIPTION
Number(s) below refer to circled number(s) on the diagnostic chart.
1. If a DTC 43 is not set, but a knock signal is indicated while operating at 1500 rpm, listen for an internal engine noise. Under a no load condition there should not be any detonation, if knock is indicated, an internal engine problem may exist.
2. Usually a knock signal can be generated by tapping on the right exhaust manifold. This test can also be performed at idle. Test Number 1 was run at 1500 rpm to determine if a constant knock signal was present, affecting engine performance.
3. This tests whether the knock signal is due to the sensor, a basic engine problem, or the KS module.
4. If the module ground circuit is faulty, the KS module will not function correctly. The test light should light indicating the ground circuit is OK.
5. Contacting CKT 496 with a test light to 12 volts should generate a knock signal to determine whether the knock sensor is faulty, or the KS module can't recognize a knock signal.
DIAGNOSTIC AIDS
Scan tools may be used to diagnose the KS system. The knock signal can be monitored to see if the knock sensor is detecting a knock condition and if the KS module is functioning, knock signal should display "YES," whenever detonation is present. The ECM can retard the timing up to 20 degrees.
If the KS system checks OK, but detonation is the complaint, refer to Diagnosis By Symptom / Detonation, Spark Knock See: Computers and Control Systems > Symptom Related Diagnostic Procedures > Detonation/Spark Knock/Pings
May 3, 2018 at 7:21 AM
JOSHBASLER 808
  • 14 POSTS
Knock sensor is the only thing that has not been replaced. I just did not see it making that much of a problem when it does it it is almost like a bad IAC valve. It surges and looses all power and seems like it is not at full power ever like it is running with the timing retarded all the time. I have checked timing several times and went through wiring and it is not a all the time thing it is only here and there. I will try to check it Tomorrow on lunch or just replace it .
May 3, 2018 at 11:40 AM
The knock sensor will not cause surging at idle. The surging idle is either a vacuum leak, check around the base of the throttle body, or a idle air control valve.
May 3, 2018 at 9:16 PM
JOSHBASLER 808
  • 14 POSTS
It runs fine at idle just not at low rpm and occasionally at high rpm's like when you go to pass somebody.
May 3, 2018 at 10:49 PM
JOSHBASLER 808
  • 14 POSTS
And it does not seem like the transmission knows what gear it should be in.
Okay.
If it is when it is moving, look for possible catalytic converter blocked, low fuel pressure or EGR valve opening and closing.
As far as the transmission, it could definitely cause the surging as well.
May 3, 2018 at 10:51 PM
JOSHBASLER 808
  • 14 POSTS
No catalytic converters and good fuel pressure EGR is working correctly no vacuum leaks. I am at a loss. It does it more so before engine is warmed up. Also, I have replaced both coolant sensors.
May 3, 2018 at 10:54 PM
JOSHBASLER 808
  • 14 POSTS
Starting to think it is not motor related that it is in the transmission somewhere.
May 3, 2018 at 10:55 PM
Very possible. You could try manually shifting it and see if it still does it.
May 3, 2018 at 11:06 PM
JOSHBASLER 808
  • 14 POSTS
I am confused as to why it only does it occasionally.
May 4, 2018 at 12:05 AM
JOSHBASLER 808
  • 14 POSTS
It was constant until I put a new ECM in it then stopped for a week now it does it rarely when first taking off or at high rpm's, but does not do it long.
May 4, 2018 at 12:12 AM
Why did you replace the ECM?
ECM fail for a reason. If the reason is not found it will fail again.
May 4, 2018 at 12:28 AM
JOSHBASLER 808
  • 14 POSTS
I have not found any reason it failed. There were some sensors that had bad wiring but I fixed all that before putting in the new ECM and new ground straps.
May 4, 2018 at 12:44 AM
Did you follow all the ohm checks in the instructions with the new ECM to check for shorted solenoids? That is the main reason they fail.
May 4, 2018 at 12:46 AM
JOSHBASLER 808
  • 14 POSTS
No I did not. There was nothing with the ECM they swapped the chips out from my old ECM to the new one and gave it to me.
May 4, 2018 at 12:47 AM
There is a check sheet in the box that gives you pins to check with an ohmmeter for specific resistance values. It sounds like they did a sway for you but never gave you those instructions.
May 4, 2018 at 1:34 AM
JOSHBASLER 808
  • 14 POSTS
Yes, they kept the box so I just stuck the new ECM in and went.
May 4, 2018 at 1:48 AM
JOSHBASLER 808
  • 14 POSTS
I hooked the scanner up and there is nothing coming from the knock signal and when I went to look at the timing advance or retard it stopped surging before I could check it.
May 4, 2018 at 3:21 AM
JOSHBASLER 808
  • 14 POSTS
Watched spark advance drop a lot every time it was surging.
May 4, 2018 at 3:30 AM
Yes, common. See if they have the box and get the sheet from the inside and do the checks.
May 4, 2018 at 3:31 AM
