Error code U0129
80,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
GAVIN GRAY
I have an error code U0129 (Not communicating with brake control module), resulting in loss of speedometer and power steering, and obviously no ABS. I have checked everything I can including:
Replace ABS with ECU unit.
Checked power and ground to ABS unit.
Checked CAN supply to ABS (2.6v at socket).
Checked fuses.
Replaced gearbox speed sensors.
Checked all wiring and connections that I can find.
Does anyone have any other ideas as to what I could check next? Am getting very frustrated with this.
Jan 17, 2020 at 11:01 PM
Good afternoon,
Did you have the ABS module flashed to your VIN number? It is not a plug and play. It must be programmed to your car.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Jan 18, 2020 at 3:16 AM
