Code p3409
96,000 MILES • 2WD • AUTOMATIC
JIM PITSINGER
What is this error code and what does it mean? I bought the car listed above used January 2021, and 3 months later I get a check engine light. Had it scanned and p3409 came up. I really can’t afford repairs much and I have to get the car emissions inspected by the end of the month. Any ideas?
Feb 2, 2022 at 5:57 AM
SQM
  • 6,383 POSTS
The code:
P3409 - Cylinder 2 Deactivation/Intake Valve Control Circuit/Open
It could be triggered for a number of reasons.
It could be due to low oil pressure, faulty cylinder deactivation solenoid, or a harness for the solenoid.
The cylinder deactivation is meant to conserve fuel and improve efficiency.
I was not sure that the Focus has cylinder deactivation.
Are you experiencing any drivability issues?
Let me know if you have any questions.
Feb 2, 2022 at 6:49 AM
JIM PITSINGER
No driving issues, works fine but won’t pass emissions with a check engine light on. Was wondering how much it would cost to fix.
Feb 2, 2022 at 7:34 AM
SQM
  • 6,383 POSTS
Can you tell me what size engine is in your vehicle? Also, if it is turbo charged or naturally aspirated?
Are there any other codes?
I want to make sure that to code you got is the P3409 and not P0349.
Feb 2, 2022 at 10:49 AM
