error code p1589
2007 TOYOTA VITZ
71,785 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
WANDULU
after changing the battery, the engine check light comes on when I start driving the car. what could trigger this?
Feb 1, 2017 at 5:02 PM
HMAC300
  • 48,601 POSTS
we do not have that model in the US so no code shows up.
Feb 1, 2017 at 9:34 PM
STEVE W.
  • 15,344 POSTS
The Vitz was sold in the US as a Yaris as a point of reference.
When you changed the battery the PCM "forgot" the zero point for the throttle and is telling you that it needs to be done so it can tell where the throttle actually is. You need a good scan tool and under the special tests area you will find the procedure to reset it.
The manual for some other Toyota's show a method using a jumper wire but not for your vehicle.
Feb 1, 2017 at 10:00 PM
