error code p0401
167,000 MILES • 2.0L • V6 • 2WD • AUTOMATIC
49ERFAITHFUL1
  • 27 POSTS
What are possible problems with the car showing error code p0401?
Jun 13, 2022 at 3:37 AM
  • 110,246 POSTS
The specific code you have indicates "Insufficient EGR flow".
EGR stands for exhaust gas recirculation. Basically, the exhaust is drawn back into the engine to burn any unburned fuel via this system.
Since the code indicates there is a restriction, we either have a corrosion (carbon) build-up in the EGR valve, in the intake manifold itself, a vacuum leak, or the valve is not properly opening.
Here is what I need you to do. There is an air inlet tube between the air filter box and the throttle body. The EGR is under that area and mounted to the intake.
If you look at the pic below, I attached what it looks like. First, in yellow, I identified a vacuum hose that is attached to it. Make sure that hose is attached and not damaged, dry rotted, or cracked.
If the hose is good, we have two ways to do this. I would attach a vacuum pump to the EGR valve vacuum hose and see if the EGR is able to hold a vacuum. If it can't, the EGR valve needs to be replaced. If it can, then I would remove it and inspect for any blockage in the valve and inside where it is mounted on the intake.
I circled the two bolts and a steel tube that will need removed so the valve and be removed and inspected.
Let me know if you are comfortable doing these things. I'm here to help, so don't be afraid to ask questions.
Also, let me know how the vehicle is running. For example, does it have a rough or uneven idle?
Let me know what you find.
See pic below.
Jun 13, 2022 at 12:48 PM
49ERFAITHFUL1
  • 27 POSTS
Thank you for answering so quickly. I'll probably take the car into the shop I always use, but I like to go in looking like I know what I'm talking about. I'm female, but I can do a lot of the simple repairs myself. I'll just feel better about this one being done at the shop, as long as it's not too costly.
Jun 13, 2022 at 11:51 PM
  • 110,246 POSTS
You are very welcome. I agree with your thoughts about being educated prior to going in. Once they realize you know what you're talking about, they are less likely to take advantage. LOL
Listn, you are always welcome here, so feel free to come back anytime in the future if you have questions or need help.
Take good care of yourself,
Jun 14, 2022 at 12:52 PM
