Error code P0141, bank 1 sensor 2
200,000 MILES • 6 CYL • AUTOMATIC
MISTY ZIPF
  • 6 POSTS
I had gotten the error code P0141 and changed the sensor and started the car and drove a while thinking my check engine light would shut off, but it has not. then I noticed that my D4 light has not come on? What could possibly be the problem? And how can I manually reset the ECU?
Jun 5, 2017 at 7:38 AM
  • 55,649 POSTS
That code means the heater in the second oxygen sensor has gone out so you need to replace the sensor, here is a guide that will help you get the job done.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
and
https://www.2carpros.com/articles/check-engine-light-clear-codes
Cheers, Ken
Jun 8, 2017 at 3:54 AM
MISTY ZIPF
  • 6 POSTS
I replaced the sensor cleared the code and drove half a block and the same code came back on?? I had replaced the sensor & made sure that the plug was clean before I connected it ..I also noticed that my car isn't quite shifting on time and it is shifting hard??
Jun 8, 2017 at 2:45 PM
  • 55,649 POSTS
This could be a sign that the catalytic converter is plugged and needs replacement. Here is a guide to confirm.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Jun 9, 2017 at 9:24 AM
