Error code P1658?
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEBIDO88
  • 8 POSTS
We scanned my car and it is code P1658.
ETCS control relay on malfunction
TACM relay stuck on
I pulled out the backup fuse hoping it would clear the ets but no.
Can't figure it out.
Jun 21, 2023 at 12:51 PM
DEBIDO88
  • 8 POSTS
I also want to mention my husband cleared the code with the reader and he drove the vehicle with no problem, no engine light, VSA, or exclamation warning lights.
Turned the car off and back on and warning lights back on and p1658 error code.
Jun 22, 2023 at 1:18 AM
  • 110,248 POSTS
As far as the code is concerned, it is related to the components you mentioned. I have the diagnostics, but they are extensive. However, I would like to at least check the relay itself and its circuit. Pic 3 explains what to check.
Also, here is a link you may find more informative:
If you look at the pics below, it explains how to test it. Do this and let me know the results. If you find it is good, I will provide the additional diagnostics, but they do require a scan tool that can communicate with the vehicle and some extensive wire testing.
Jun 22, 2023 at 2:27 PM
DEBIDO88
  • 8 POSTS
Hi, my husband is an electrician and switched the etcs relay with other ones and he said it is fine.
Yesterday I filled the tank with gas and drove around for 10 minutes . Got home and restarted vehicle and no warning lights.
My husband went out later and the lights back on. He cleared the code with a different scanner and cleared code and no codes showed.
I went out today and the warning lights back on cleared code. I drove for 15 minutes and got home and restarted vehicle and no warning lights again.
Jun 23, 2023 at 4:54 AM
  • 110,248 POSTS
Your husband is an electrician? Excellent! That makes my life easier. LOL
It sounds like the problem is intermittent. Was he able to confirm there isn't a corrosion issue with the connectors or a pushed-in pin?
Jun 23, 2023 at 1:35 PM
DEBIDO88
  • 8 POSTS
He took the relay out and cleaned it. Also checked the battery. Started the vehicle and no warning lights. Started it 5 times no lights then the engine light, VSA and exclamation point and P 1658.
This is crazy, lol.
Jun 24, 2023 at 1:30 PM
  • 110,248 POSTS
I was hoping it was something easy, but it never seems to work out that way. LOL
I attached the full list of the diagnostics below. Have your husband take a look at them and see if he feels comfortable performing. Chances are he will, but if either of you have questions, let me know.
joe
Jun 24, 2023 at 2:21 PM
DEBIDO88
  • 8 POSTS
How do you do this?
Jun 24, 2023 at 9:31 PM
  • 110,248 POSTS
Basically, you are checking things like continuity and voltages at specific wiring pins at the connectors and at the PCM connector.
Jun 25, 2023 at 1:42 PM
DEBIDO88
  • 8 POSTS
My husband wasn't able to check wiring.
Today I started it warning lights there so cleared code p1658. Then turned key on and engine light flashed 5 times then went off.
I was wondering if I should change the gas cap?
Jun 27, 2023 at 9:47 AM
  • 110,248 POSTS
The gas cap is tied into the evaporative emissions system and isn't part of the circuits having the issue.
The tests I listed above are what I feel need to be done. The only other thing I can suggest is to try scanning the can-bus.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. It does require a scanner that can perform this, but they aren't uncommon.
Here is a link showing how it's done:
I guess what I'm saying is there could be something other that could help us narrow it down without the diagnostics above.
Let me know your thoughts.
Jun 27, 2023 at 12:10 PM
DEBIDO88
  • 8 POSTS
I did a full scan with Blue driver and P1658 comes up also B1177 low voltage battery.
Jun 28, 2023 at 8:49 AM
  • 110,248 POSTS
The battery could be low from testing. I would suggest charging it. You don't want a weak battery because on today's vehicles, voltage is very important.
If I help, would your husband feel comfortable performing the test I listed above? That is where we need to go next.
Jun 28, 2023 at 2:05 PM
DEBIDO88
  • 8 POSTS
We changed the battery because it was over 5 years old.
The warning lights are still coming on.
I discovered this, I turn the key on and 3 warning lights, then turn the key off then on again and just engine light and I can drive it without having to clear the code.
Do you have the wiring information for the ETCS?
Thank you for all the great information.
Jun 30, 2023 at 1:14 AM
  • 110,248 POSTS
I attached the wiring schematics below for the traction control/ABS system. I had to cut each page in half to make them readable, but I did overlap the two so you can follow from one to the next.
I hope this helps.
joe
Jun 30, 2023 at 2:21 PM
