Error codes U016400 and P068A00?
2013 VOLKSWAGEN GOLF
39,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ABIE
I stack on parking position this fault code U016400 and P068A00.
May 25, 2023 at 1:51 AM
  • 55,421 POSTS
It sounds like the Main PCM relay needs to be replaced.
U0164: This code is typically defined as "Lost Communication with HVAC Control Module."
P068A: This code means "ECM/PCM Power Relay De-Energized Performance - Too Early."
May 25, 2023 at 9:48 AM
