Rpms have been very erratic?
147,200 MILES • 3.5L • AUTOMATIC
BSM1984
My rpms have been very erratic. I barely press on the gas and it's going to 3000 rpms. It's gotten worse especially after at stop signs and red lights.
Just had an oil change and serpentine belt replaced this past Monday. I had more transmission fluid added in June no leaks from that. Also my gas mileage has gotten worse. It did give me a p0700 code today that's the first time
Aug 22, 2026 at 8:31 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Request the transmission-module codes and written findings behind the clutch-damage diagnosis. Ask the estimate to identify cooler-line repair, the proposed transmission, torque converter, required cooler cleaning or replacement, fluid and any setup work. Compare complete installed quotes rather than the price of a transmission alone. Confirm exact application compatibility and written parts-and-labor terms with the installing shop before buying a separate unit. If fluid loss and loss of drive remain, arrange transport instead of trying to drive it to another shop. A documented diagnosis and comparable complete estimates can help you choose a repair that addresses both the damage and the original leak.
Guidance references and applicability
ZF: Transmission-oil service information https://aftermarket.zf.com/sg/aftermarket-portal/faq/faq-oils/ General support for correct fluid selection and level. This is not a Chrysler, Chevrolet or Honda transmission specification, nor evidence that those vehicles use a ZF unit.
Read the replies · Discussion summary and reported outcome
  • 110,248 POSTS
Hi:
When you say the RPMs have been erratic, do you notice it when accelerating or when the vehicle is sitting idle?
I ask because the code you have, P0700, is related to the transmission. This diagnostic trouble code (DTC) indicates the transmission control module (TCM) has set an emission-related transmission DTC. The engine control module (ECM) receives the TCM information over the serial data circuit. The ECM illuminates the malfunction indicator lamp (MIL) when the TCM sends a message over the serial data circuit requesting MIL illumination. The DTC information for the ECM will only display DTC P0700, but the freeze frame/failure records data may display the transmission DTC that was set.
Do you have access to a scan tool that can read freeze frame info and codes other than engine codes?
Aug 22, 2026 at 7:31 PM
BSM1984
At idle at one point it was going between 500 to 1000 rpm. I just have a standard obd2 scanner.
Aug 22, 2026 at 7:45 PM
  • 55,694 POSTS
Is the transmission fluid full? I would check that first.
Aug 24, 2026 at 5:22 PM
BSM1984
Yeah I took it too a shop today. The transmission cooler lines gave up. The clutch pack was fried so quoted $6800 for a new transmission
Aug 24, 2026 at 5:27 PM
  • 55,694 POSTS
Hmm, sorry about that, it happens, you might want to try a used transmission so save money. Low miles from ebay?
Aug 25, 2026 at 6:55 AM
BSM1984
Yeah the repair shop it's at won't let me do that I even asked because I found one totally rebuilt with the torque converter. And it was $2000 less then there quote
Aug 25, 2026 at 7:06 AM
  • 55,694 POSTS
Yep, some shops wont do want you want them too, you might want to shop around.
Aug 25, 2026 at 7:50 AM
Discussion summary
The owner reported P0700, unusual engine speed and transmission concerns. The owner later said a shop found failed cooler lines and damaged clutch packs and quoted a replacement transmission. The discussion then turned to replacement cost and whether the shop would install an owner-supplied unit.
Reported outcome: The owner reported a shop diagnosis and replacement quote. No completed repair or restored operation was reported.
The shop findings were relayed by the owner and were not independently inspected. The discussion does not validate a particular replacement unit or price.
Read the original discussion
