An idle that is high or one that is "searching" is usually do to a vacuum leak. A vacuum leak or intake leak is defined as any unmetered air entering the air intake system from the Mass Airflow [MAF] sensor to the engine's combustion chambers. So if you could please do a visual inspection of the air intake tract, vacuum hoses, and the EVAP system looking for misaligned components, broken or cut hoses, or loose connections. Here is a link below with a guide on how to do this:
Please go through this guide and get back to us with what you are to find out and we can go from there.
Thanks,
Alex
2CarPros
Oct 23, 2019 at 5:14 PM
