Erratic electrical
154,000 MILES • V6 • 2WD • AUTOMATIC
KTUCKERHOYT62
  • 10 POSTS
gauges pegging out and all warning lights coming on while driving.
Dec 4, 2019 at 4:23 PM
JONNYB1963
  • 263 POSTS
Sounds to me like you have a loose ground to the Instrument Cluster. Its a pretty common thing. This is where I would start if I were you.
On this vehicle there are two ground wires from the cluster, one goes to the left hand side, behind the dash panel and bolts to a stud on the body, The other goes to right side behind the dash and also bolts to a stud. You should check both of them.
You will need to get a flashlight and get under the dashboard and locate them. When you find them, give them a wiggle and if they move, tighten the nut to secure them back in place.
Start there and let me know what you find!
Regards
Jon
Dec 4, 2019 at 11:12 PM
KTUCKERHOYT62
  • 10 POSTS
Checked both sides ground wires no wiggle and verified with ohmmeter they are making good connection, meanwhile been doing a lot of research (we took car to 2 auto places they both said battery and alternator was good). i found alternator test and diode test that i performed this morning diodes tested bad. Thanks for your reply.
Dec 5, 2019 at 12:59 AM
JONNYB1963
  • 263 POSTS
Ah okay!
Well it sounds like you've found the problem!
Come back and see us if you need anything else!
Jon
Dec 5, 2019 at 2:16 AM
