Equinox 2005 Ignition?
200,000 MILES • 4.5L • 2WD • AUTOMATIC
EQUINOXOWNER05
About four days ago i went to start my car, i had the cab light on because it was night. I started my car and turned off the cab light, my car instantly shut off and would not start back up or the dash lights will not turn on. I hooked up a battery charger and set it to jump start but nothing. When i put the key in the on position and move the shifter up and down the dash lights will flicker as if the battery is low but the battery is fully charged with 12v reading. I even checked all fuses, under the hood and in the cab, and all fuses are still good. Whenever it feels like it, it will start and runs normal and fine. Could it be the ignition? Or is it an electrical problem? I have an after market radio installed and even switched it back to the stock radio to be sure it was not my radio draining the battery or causing a short.
Mar 23, 2017 at 8:57 PM
HMAC300
  • 48,601 POSTS
try a security system reset it may be that due to the battery problem if it does not work then have the ignition switch checked. see link
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 23, 2017 at 11:27 PM
EQUINOXOWNER05
Thank you for the reply. Turns out my vehicle is on recall. When i start the car and put it in drive i can remove the key and it will still run. I also can put the key in the on position and remove it while in drive. The recall deals with the ignition. https://www.cars.com/recalls/chevrolet-equinox-2005/?zc=87401
Mar 24, 2017 at 3:42 AM
HMAC300
  • 48,601 POSTS
ok I never checkd that in manual.
Mar 24, 2017 at 5:24 AM
