EPS light on?
140,000 MILES • 1.7L • 2WD • AUTOMATIC
SOLOMON EHIWARIO
Greetings, please I need help for my car.. the steering is heavy and EPS light is on the dash board. My technician advised me to get another EPS control unit which i got from the same model of the car but from a diesel car. The problem still the same and my technician advise I get another EPS control with a matching parts number for it to activate the rack. This is diagnosis result.
1. A problem with circuit torque sensor Amp.
2. A problem with voltage for torque sensor VT3 and VT6 .
3. Excessive charge of the vehicle speed sensor signal.
4. A problem with the engine speed signal circuit.
5. A problem with the motor voltage.
6. Fail -safe relay.
Please what can i do to fix this? it is driving me crazy. Solomon from Nigeria.
Feb 27, 2018 at 10:38 PM
MIKE H R
  • 3,094 POSTS
9 times out of 10 it will be the power steering motor here are the instructions on how to change it out in the diagrams below. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Mar 1, 2018 at 1:19 AM
SOLOMON EHIWARIO
thank you for your help I got a used unit worked great! I love this website :)
Mar 1, 2018 at 5:05 AM
  • 55,711 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Mar 1, 2018 at 7:06 AM
2CP-ARCHIVES
  • 4,540 POSTS
2001 Honda civic EPS light appear in dash and the steering get stiff what is the possible causes
Jan 8, 2021 at 3:28 AM (Merged)
BLAZE45
  • 380 POSTS
The computer that controls the system is having an issue connecting with corresponding sensors. It can be intermittent and it is one of the only codes that the dealership can pull. If it stays on, have them check the code. You can often reset it by just turning the car off for a moment then starting it back up and if that doesnt work do a hard reset by pulling the negative battery cable off. Good luck.
SOLOMON EHIWARIO
Pls can eps control unit that was pulled out from diesel car work on the car that uses petrol?
  • 55,711 POSTS
Yep should be the same.
Cheers, Ken
